Sorry, haven't been printing for a while. - No, its not a mac. I haven't had those problems in earlier versions. Right now the problem is that I can't rotate the model any more. Cura is starting to slice instantly after loading the model. After rotating, the model is still not beeing rescliced and the old toolpath is shown in layers view.
- nothing except the printer is connected
- its a very simple model, also with other models the same thing happens
- the virus software is called "Managed Antivirus" and I can't simply deactivate it at work
gr5 2,333
Is this a Mac? There used to be issues like this on the Mac. This sounds extremely annoying and I haven't heard anyone else have this problem in a while but you can clear the platform, get all the settings perfect and then load the model at the last minute if you want to slice only once.
But you shouldn't have to do this. Some things that have messed up cura slicing in the past:
anti-virus software
things plugged into USB
SD cards or similar removable drives.
millions of triangles to slice. Or billions.
Does it do this on all models or just a particular model? Try a simple cube.
