Adaptive Infill / Hyperbolic Tesselation
ted
Posted · Adaptive Infill / Hyperbolic Tesselation
Hi all,
I've been printing quite allot of largish (30 - 40) hour builds for use in education.
Infill seems to be eating quite allot of time/material in the build process.
Is there a method to create a more adaptive infill? At the moment I've experimented with using Maya to generate a series of gradually enlarging cells (dense at surface, less so at core), and this helps a bit but is horribly laborious.
Currently for very large objects I'm printing them hollow and manually adding internal buttressing/columns to support overhangs/ceilings and limiting warping (again this is partially via a script in maya).
Any thoughts on generating infill with http://www.plunk.org/~hatch/HyperbolicTesselations/ as I dimly remember them being discussed on a reprap forum several years ago for very similar reasons?
Although generating something like this, especially for a gribbly object, may well increase slice time quite dramatically if overall print time/material use is reduced then it might be worthwhile?
    Adaptive infill is quite a challange to implement for me right now. But, if you want, I have a version that can do "infill every X layers". This isn't in a public release yet, but if you want, I can send you a test version.
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 17 replies
