Thank you for your answer.
The pulley seems fine. i have tried to print another Gcode file exported by a friend and it is working perfectly.
I recon there might have been a Bug while exporting.
I am exporting from Rhino to Cura. Has anyone already experienced this kind of issues?
IRobertI 473
You likely have a loose pulley. Tighten up the set screws that hold them in place.
(the image shows an UM2 but the same applies on the original)
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#shifted
