Dim3nsioneer, thanks for your reply. I wanted to download the plugin as the one that is in my plugin directory does not work as expected, it does not pause at the requested height. I will have to find a solution for that...
Dim3nsioneer 551
What printer do you have? The pause at height plugin distributed with Cura was written by Daid himself; he made some fixes for this plugin some time ago afaik.
- 1 month later...
I'm very eager to use the pause at height plugin. Mainly for swapping filaments, so that the objects I'm printing can be two colors. Could anyone take me through the process in Cura of how to do this. It would be greatly appreciated. Thanks!
Dim3nsioneer 551
Go to the 'Plugin' tab in Cura, select the PauseAtZ plugin and press the button with the down arrow... done!
Well, you have to adjust the value for the height...
Dim3nsioneer 551
You don't need to download the plugin. It's part of the Cura distribution (it's called Pause at height in the plugin tab).
