plugin download fail??
middelbh
Posted · plugin download fail??
Dim3nsioneer, thanks for your reply. I wanted to download the plugin as the one that is in my plugin directory does not work as expected, it does not pause at the requested height. I will have to find a solution for that...
    I'm very eager to use the pause at height plugin. Mainly for swapping filaments, so that the objects I'm printing can be two colors. Could anyone take me through the process in Cura of how to do this. It would be greatly appreciated. Thanks!
    Go to the 'Plugin' tab in Cura, select the PauseAtZ plugin and press the button with the down arrow... done! :)
    Well, you have to adjust the value for the height...
