Posted · Layers view graphical issue
Maybe you could explain a bit more what's annoying you?
Lacking extrusion display?
    Mikk36, are you using any plugins? It looks like Cura incorrectly detected the layer height for some layers, which is odd...
    Was using Flow Thermostat, but it also happens without any plugins enabled.
    issue4
    issue5
    You're right in saying that it looks like very small extrusions, even though they print out correctly. The place where this happens also changes every time it loads the generated gcode.
    My Cura profile string:
    ;CURA_PROFILE_STRING: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
    I think the "cool lift head" feature seems to be causing your rendering issue. Which kinda make sense (for me) as it does extra Z moves that the GCode reader sees as layer changing moves.
    Nevertheless, it's an issue with Cura, so you can maybe fix it in the unforeseeable future :)
