When I initially installed the Z stage the 12mm steel posts/axes would not both go through the the linear bearings in the tray and the holes at the bottom of the printer floor.
There was a 5mm difference between the distance between the axes holes in the printer and the distance between the linear bearings in the tray.
I loosened the bolts holding the tray together in order to be able to seat the axes into their holes however now the Z stage has separated at the rear and is in danger of coming apart completely
Have I just made an error on how tight these tolerances are? It seemed to me that if I tried to separate the axes by force into the bottom holes in the printer something would break.
it is by design that the tray has no connection to the arms towards the back. this is to provide additional springiness towards the back, to get the same springiness as the front.
Thanks for that. I pulled the Z stage out of the cage and tightened it all up again - this time it went in no problem. I just moved the Z stage to the top when fitting the posts into their bottom holes and it was snug but perfect.
joergen 2
