What feeder are you using? The stock feeders lightest setting is pretty tight. If you're a hands on kinda guy, you can try printing your own feeder and going lighter on the spring tension. Helped for me anyways.
I changed the feeder due to this issue. I'm now using the Irobertl v2 feeder. I find if the tension is too light the filament will grind rather then flatten.
solid-print-3d 30
