Large Object Stalls Cura
ice086
Posted · Large Object Stalls Cura
I am working on slicing a rather large complex object. It is an ODST helmet from the Halo series of games. The link to it can be seen below. I am attempting to print this helmet as a demo piece to show what my machine can do.
I am attempting to run it at 279mm tall on a very large delta printer. When I attempt to use the following settings for the object it almost completes but stalls out at about 90%. I can still use Cura but slicing has stopped. I am able to complete the slicing process when I use no Support but I cannot complete slicing when I use Support Touching Build Plate.
Cura Version: 14.07
Layer height 0.1mm
Infill: 0%
Wall thickness 2.0mm
Support: Touching Buildplate
No bottom layer (object is open on the underside)
I am doing the slicing on a rather robust gaming machine so processing and graphics power is not an issue. I know that the slice has stalled out because I follow its progress using the Slicing bar and by watching my the fluctuations in my CPU from task manager.
If anyone has any suggestions please let me know!
Link to helmet:
http://www.bluerealmstudios.com/2009/09/15/legacy-odst-helmet/
    Somehow it managed to slice it this time when I ran it but Python ran up to 367.6 MB. The previous times were along the same lines.
    If it helps I can run it a few more times and record how much memory python uses when it stalls out compared to when it completes.
    Well, I was wondering if it was the python process getting out of memory (which happens around the 2.5GB mark, so you are not close to that)
    But, support material is very CPU intensive right now, so it could be that it is working, but very slow.
    It's single threaded. So it will only go to 100% when you have a single core.
    Thanks to some assistance from Ice086 I think I have a solution for this bug.
    This bug prevents you from generating gcode files bigger then around 250MB, most likely this limit is only on Windows. I'm working on fixing this, as I've found a solution, but need to verify a lot of other code because of this.
    As far as I and Ice086 could test, this problem is gone in my latest test version 14.09.1-RC1:
    http://software.ultimaker.com/Cura_closed_beta/
    I encountered same issue when running Cura - it refused save .gcode anywhere (memory was about 600 megs I think). By luck I found out that in my case it agreed to finally save something when I tried to owerwrite some another already existing file. Thought that I say it if somebody encounters same problem.
    Would be nice to know if your problem was solved by the 14.09.1-RC1
