aratome 0 Report post Posted September 24, 2014 in X-shaft falling out I have a 2-week-old Ultimaker2, which was printing well until it started showing some skew. Turns out that the X-shaft, which runs front-to-back along the right of the instrument was falling out of the bearing located at the front right. If I put it back in, it will eventually pop out again as the printhead moves around. Looking at it more carefully, and after removing the motor cover, it looks like the short belt between the X-motor and this shaft are at an odd angle, with the pulleys too far forwards on the shaft. This could be pulling the shaft backwards and causing the problem. I could move the pulleys backwards and re-home the printhead, but wasn't sure if this was the correct approach. Finally, with the machine off (and the shaft located in its bearing), I can manually move the printhead in Y fairly easily, but its much stiffer and less smooth in X. I have some pictures, but couldn't see how to post them here. Thanks for any help! Share this post Link to post Share on other sites
illuminarti 16 Report post Posted September 24, 2014 in X-shaft falling out Yes, you can push the bearing all the way in, and then loosen the grub screws on the two pulleys in the back right corner, and push them all the way to the back, while holding the rod fully inserted. Then re-tighten the grub screws - and that will keep the rod in place. That's probably what is causing the rough movement as well. At the very least, fix the pulleys first, and then see what needs to be done. BTW, front to back is the y-axis, so those long rods are generally considered the y-axes. Although the motor that attaches to that rod is, indeed, the x motor. :-) Share this post Link to post Share on other sites
