Most likely disabling "fix horrible type A" works around your problem.
The main issue is most likely that Sketchup is generating horrible meshes again (it's great at generating horrible meshes, and you might want to look at designspark mechanical)
look on the right at the view options: the x-ray view.
If you see any red in your model, its bad.
pm_dude 27
Yeah you need to use the Gallery and Upload from there. Then use the MyMedia button and insert your image(s).
