UM original retract on startup Cura 14.07
qwarks
Posted · UM original retract on startup Cura 14.07
Hi guys.
I have tried to use Cura 14.07 to generate gcode for my UM original.
I use prontrface to send the gcode.
The firmware is updated to the newest.
When i press print in prontrface the printer seems to start like normal, but when it gets to the middle of the platform to start the print, the extruder retracts like 20-30mm and then it starts to print - ofcourse nothing comes out.
Here is the beginning of my gcode:
M92 E865.888000
;Sliced at: Sat 27-09-2014 13:33:44
;Basic settings: Layer height: 0.2 Walls: 0.8 Fill: 10
;Print time: #P_TIME#
;Filament used: #F_AMNT#m #F_WGHT#g
;Filament cost: #F_COST#
;M190 S70 ;Uncomment to add your own bed temperature line
;M109 S0 ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z5.0 F9000 ;move the platform down 5mm
G1 F9000
;Layer count: 217
;LAYER:0
M107
G0 F9000 X68.38 Y73.25 Z0.30
;TYPE:SKIRT
G1 F1200 X70.29 Y71.54 E0.04821
G1 X71.29 Y70.72 E0.07263
G1 X71.37 Y70.66 E0.07443
G1 X72.07 Y70.06 E0.09185
G1 X73.44 Y69.16 E0.12271
G1 X73.48 Y69.14 E0.12358
G1 X74.40 Y68.46 E0.14508
G1 X76.66 Y67.04 E0.19522
G1 X79.85 Y65.61 E0.26090
G1 X83.11 Y64.81 E0.32407
G1 X85.46 Y64.53 E0.36859
G1 X87.44 Y64.49 E0.40588
G1 X87.52 Y64.49 E0.40743
G1 X88.67 Y63.94 E0.43134
G1 X97.43 Y65.53 E0.59887
G1 X100.14 Y66.73 E0.65472
G1 X100.91 Y67.08 E0.67052
G1 X102.20 Y67.72 E0.69773
G1 X103.97 Y68.72 E0.73587
G1 X106.13 Y70.26 E0.78579
G1 X107.64 Y71.55 E0.82315
G1 X109.01 Y72.87 E0.85902
G1 X110.58 Y74.63 E0.90333
G1 X112.11 Y76.74 E0.95240
G1 X113.38 Y78.90 E0.99945
G1 X114.37 Y81.02 E1.04356
G1 X115.14 Y83.14 E1.08601
G1 X115.76 Y85.43 E1.13063
G1 X116.16 Y87.80 E1.17581
G1 X116.31 Y89.68 E1.21117
G1 X116.33 Y91.43 E1.24411
G1 X116.19 Y93.73 E1.28752
G1 X115.84 Y95.93 E1.32945
G1 X115.33 Y98.05 E1.37034
G1 X114.61 Y100.19 E1.41289
G1 X113.71 Y102.26 E1.45532
G1 X113.14 Y103.32 E1.47798
G1 X113.37 Y103.75 E1.48721
G1 X114.30 Y106.18 E1.53609
G1 X114.92 Y108.24 E1.57664
G1 X115.42 Y110.71 E1.62392
G1 X115.64 Y113.17 E1.67048
G1 X115.68 Y114.92 E1.70337
G1 X115.55 Y117.09 E1.74422
G1 X115.14 Y119.97 E1.79894
G1 X114.32 Y122.72 E1.85291
G1 X113.49 Y124.81 E1.89531
G1 X112.61 Y126.64 E1.93351
G1 X111.68 Y128.24 E1.96820
G1 X110.70 Y129.70 E2.00140
G1 X109.39 Y131.33 E2.04063
G1 X108.05 Y132.78 E2.07783
G1 X106.49 Y134.23 E2.11786
G1 X104.66 Y135.66 E2.16154
G1 X102.89 Y136.82 E2.20135
G1 X101.14 Y137.80 E2.23900
G1 X99.36 Y138.63 E2.27599
G1 X97.55 Y139.32 E2.31240
G1 X95.74 Y139.89 E2.34813
G1 X93.78 Y140.34 E2.38606
G1 X92.08 Y140.62 E2.41838
G1 X90.31 Y140.80 E2.45189
G1 X88.19 Y140.87 E2.49185
G1 X86.24 Y140.78 E2.52842
G1 X85.05 Y140.65 E2.55095
G1 X83.41 Y140.40 E2.58216
G1 X81.51 Y139.98 E2.61874
G1 X79.78 Y139.47 E2.65266
G1 X78.06 Y138.85 E2.68721
G1 X76.28 Y138.06 E2.72374
G1 X74.58 Y137.16 E2.75983
G1 X72.89 Y136.12 E2.79729
G1 X71.20 Y134.89 E2.83662
G1 X69.87 Y133.77 E2.86920
G1 X68.64 Y132.62 E2.90106
G1 X67.61 Y131.53 E2.92914
G1 X66.39 Y130.06 E2.96511
Screenshot of machine settings in Cura 14.07:
Machine settings
    Your start.gcode is missing a 'G92 E0' for resetting the extruder position before the first line with a print command (but after the G90).
    It's also recommended to do some priming before print as it is done in the default start.gcode.
        • 6 replies
