I would heat up the nozzle and push the filament through manually. Like this you may find the spot where the resistance begins. This will give you an idea what might be wrong.
Have done this, the whole bowden portion seems very smooth. The hot end doesn't seem especially difficult to push PLA through either, comparable to my Prusa i3 w/ j-head.
Which E current values did you try?
1250 (default), 1300, 1500, 1750. None seem to make a difference.
Dim3nsioneer 559
