Strange 'dots' on print
xeo
Posted · Strange 'dots' on print
Hello everyone,
I am new to this forum and new to the Ultimaker.
So far I am liking the machine pretty much :mrgreen:
There is one strange thing though in some of my prints that I actually have no idea where to find a solution for this. I am hoping one of you can help me out :oops:
I have attached a picture of the problem. (I tried at least)
It only seem to happen at rounded surfaces as I printed a fairly large squared box and it came out perfectly fine. The rest of the print is also fine.
If someone has a solution I will be happy to read :mrgreen:
Thanks in advance!!
Chris
    I always thought that had to do with too much plastic being extruded during a 100% infill setting, the extra plastic has to go somewhere.
    Try one or more of these:
    • increase the "filament diameter" setting
    • reduce the "Fill density percentage"
    • reduce the "Filament flow percentage"
    Thanks for your reply Anthony!
    I'll give it a try and see what's happening when changing these values especially for the flow.
    Strange thing still is that I printed the Ultimaker robot (see attached) and there I don't see any problems.
    Only thing changed is layers of 0,06 instead of 0,25 mm rest of the settings identically.
    As soon as I have tried the things you mentioned I will get back with hopefully positive details.
    Thanks,
    Chris
    In my experience with cylinders this is a fairly common occurrence with Cura. You need to do one of two things; print real slow - no faster than 30, 20 is preferable. Or do it with Slic3r. If you watch the print real close you will see why it is happening. For whatever reason it does not happen with Slic3r, at least to anything like the same extent.
    ... I should add that there could be other reasons why it is happening so posting your settings would be helpful
    Thanks for all replys.
    I have tried what Anthony mentioned and see small differences in print result but the problem still occurs.
    What Yellowshark is mentioning is actually what I think is happening. It looks like the weird dots are sort of starting points of each layer. It prints until that point and than continues the other way around. Is slicing it with Slic3r the only way to fix this?
    What happens if you guys would print this? I can share the STL file if anyone of you is willing to give it a try ...
    The product is a battery box so you could use it yourself :-P
    Thanks,
    Chris
    I will be interested to see your results/conclusion.
    This website may help you for other problems:
    http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide
    This is a very handy link btw Anthony, thanks for that!!
    Some problems I have ofcourse faced already but we all did I think :oops: :-P
    I'll give it as try, can you upload it to youmagine or email me (I sent you a PM).
    Those dot's really looks like starting points of a new layer.
    Another possible cause can be that the nozzle temp is too high for the settings you have set.
    Attached a picture after playing around with Anthonys advices.
    I can still see starting/ending points but they are not 'dots' anymore.
    The problem should be in Cura.
    It seems odd that the new layers start at such random location in the original image.
    Anyway, I tried the file that XeO/Chris sent me and with my settings (mainly 50% infill I think is the key) there were no blobs. But the seam is definitely showing. Turn retraction on/off puts the seams in different places.
    I could not find a way to "attach" a text file in this forum so here is my .ini file:
    [profile]
    layer_height = 0.25
    wall_thickness = 0.8
    retraction_enable = False
    solid_layer_thickness = 0.6
    fill_density = 50
    nozzle_size = 0.4
    print_speed = 60
    print_temperature = 225
    print_temperature2 = 0
    print_temperature3 = 0
    print_temperature4 = 0
    print_bed_temperature = 70
    support = None
    platform_adhesion = None
    support_dual_extrusion = Both
    wipe_tower = False
    wipe_tower_volume = 15
    ooze_shield = False
    filament_diameter = 2.85
    filament_diameter2 = 0
    filament_diameter3 = 0
    filament_diameter4 = 0
    filament_flow = 100.0
    retraction_speed = 40.0
    retraction_amount = 4.5
    retraction_dual_amount = 16.5
    retraction_min_travel = 1.5
    retraction_combing = True
    retraction_minimal_extrusion = 0.02
    retraction_hop = 0.0
    bottom_thickness = 0.3
    object_sink = 0.0
    overlap_dual = 0.15
    travel_speed = 150.0
    bottom_layer_speed = 20
    infill_speed = 0.0
    inset0_speed = 0.0
    insetx_speed = 0.0
    cool_min_layer_time = 5
    fan_enabled = True
    skirt_line_count = 1
    skirt_gap = 3.0
    skirt_minimal_length = 150.0
    fan_full_height = 0.5
    fan_speed = 100
    fan_speed_max = 100
    cool_min_feedrate = 10
    cool_head_lift = False
    solid_top = True
    solid_bottom = True
    fill_overlap = 20
    support_type = Grid
    support_angle = 60
    support_fill_rate = 15
    support_xy_distance = 0.7
    support_z_distance = 0.15
    spiralize = False
    brim_line_count = 20
    raft_margin = 5
    raft_line_spacing = 1.0
    raft_base_thickness = 0.3
    raft_base_linewidth = 0.7
    raft_interface_thickness = 0.2
    raft_interface_linewidth = 0.2
    raft_airgap = 0.22
    raft_surface_layers = 2
    fix_horrible_union_all_type_a = False
    fix_horrible_union_all_type_b = False
    fix_horrible_use_open_bits = False
    fix_horrible_extensive_stitching = False
    plugin_config =
    object_center_x = -1
    object_center_y = -1
    [alterations]
    start.gcode = ;Sliced at: {day} {date} {time}
    ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
    ;Print time: {print_time}
    ;Filament used: {filament_amount}m {filament_weight}g
    ;Filament cost: {filament_cost}
    G21 ;metric values
    G90 ;absolute positioning
    M107 ;start with the fan off
    G28 X0 Y0 ;move X/Y to min endstops
    G28 Z0 ;move Z to min endstops
    G1 Z15.0 F{travel_speed} ;move the platform down 15mm
    ;G1 F200 E3 ;extrude 3mm of feed stock
    G1 E20 F300 ;E__mm at F___mm/s
    G1 F{travel_speed}
    ;M301 P15.40 I0.70 D85.31 C1.0
    M117 Printing...
    end.gcode = ;End GCode
    M104 S0 ;extruder heater off
    M140 S0 ;heated bed heater off (if you have it)
    G91 ;relative positioning
    G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
    G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
    G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
    M84 ;steppers off
    start2.gcode = ;Sliced at: {day} {date} {time}
    G21 ;metric values
    T1
    G1 F200 E10 ;extrude 10mm of feed stock
    G1 F200 E-{retraction_dual_amount}
    T0
    G1 F{travel_speed}
    M117 Printing...
    end2.gcode = ;End GCode
    M104 T0 S0 ;extruder heater off
    M104 T1 S0 ;extruder heater off
    M84 ;steppers off
    support_start.gcode =
    support_end.gcode =
    cool_start.gcode =
    cool_end.gcode =
    replace.csv =
    switchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
    G92 E0
    G1 E-36 F5000
    G92 E0
    T{extruder}
    G1 X{new_x} Y{new_y} Z{new_z} F{travel_speed}
    G1 E36 F5000
    G92 E0
    Hi Anthony,
    I see in your pictures that you have the exact same issue?
    Does the infill percentage really have something to do with this problem? When I am printing it it just puts two layers next to each other continuing with the next layer and so on. What I mean is that I don't see any infill happening ...
    That is a standard feature of Cura, in the older version this was called "Joris Plugin".
    Is is to prevent a visible scar when a new layer starts at the exact same point as the previous one.
    Thanks. I understand now.
    Hi Anthony,
    I guess the infill does not affect those bumps. I put it back at 100% infill and could not get the bumps that you had. I also reduced the filament diameter setting from 2.85 to 2.50 and the only effect was to have a much thicker object.
    I am using Cura 10.04-RC1.
    I am not sure that I can help you but am glad that you got rid of the bumps / nodules. Can you share with us the exact changes you made to your settings? I also noticed you used a different colour plastic ... that might be a factor also.
    Hi Anthony,
    I have no idea how to post settings of Cura.
    But the main settings I used in the last picture are:
    * Filament diameter 2,95 mm
    * Overall speed 20 mm
    * Layer height 0,25
    * Infill percentage 20%
    * Material flow 100%
    * Standard retraction settings
    * Rest of settings standard Ultimaker 2 profile
    My Cura version is 14.07
