I always thought that had to do with too much plastic being extruded during a 100% infill setting, the extra plastic has to go somewhere.
Try one or more of these:
- increase the "filament diameter" setting
- reduce the "Fill density percentage"
- reduce the "Filament flow percentage"
Thanks for your reply Anthony!
I'll give it a try and see what's happening when changing these values especially for the flow.
Strange thing still is that I printed the Ultimaker robot (see attached) and there I don't see any problems.
Only thing changed is layers of 0,06 instead of 0,25 mm rest of the settings identically.
As soon as I have tried the things you mentioned I will get back with hopefully positive details.
Thanks,
Chris
anthonyt 0
