Thanks Daid.
Will give a it with different retraction settings and slicers, like Cura.
Thanks Daid.
And, did you manage your problem with Cura ?
if yes, post your pic .
I found Cura very nice and simple prg. to work with
Slic3r has had retraction settings almost since its birth, and they do work flawlessly.
I'm almost as biased as Daid but to be honest I'm not aware of any option not working in Slic3r. Daid, what options are you talking about? If you find something not working, I'll be glad to hear so that it can be fixed. Otherwise, don't scare users
Lots of people, including common users, have been using Slic3r since the past autumn to make their everyday prints with excellent results...
It was a few versions ago, support did not work at all. And I was getting some strange slice results. I've been too busy with other things to try it again, and I know Slic3r is moving fast.I'm almost as biased as Daidbut to be honest I'm not aware of any option not working in Slic3r. Daid, what options are you talking about? If you find something not working, I'll be glad to hear so that it can be fixed. Otherwise, don't scare users
To the old problem. In Slic3r you must set the E Steps manual by change the start G-Code.
And the temp was to high. A heavy string is comming out without preasure from feeder.
And perhaps there is a setting to give each layer a min time to cool down. So the Head will slow down in the top. This option is not always good. Here, its bad.
Daid 301
The effect you see is called "stringing". It's one of the major problems with the Ultimaker design right now. What helps is retraction. I don't know if Slic3r has retraction settings, and if they work (because in my experience Slic3r does a great job at slicing, but sometimes options just don't work at all, IMHO the work they do on it is great. But it's not stable yet, and the people that are shouting that everyone should use it are not people that just want to print, but people that want cutting edge tech)
If Slic3r has retraction, try 2mm of retraction at 50mm/s. You could also try Cura, which has defaults that work great for the Ultimaker:
https://github.com/daid/Cura/wiki
but you have to set retraction yourself then at 2mm, because the default of Cura is no retraction.
