clicking sound as the printer head moves
kwatts
Posted · clicking sound as the printer head moves
Hey Guys,
My Ultimaker has started making clicking sounds when it prints.
To me it sound like a wood click, or structure shift, its either happening in the front 2 corners or on the sliding blocks.
If i turn the machine off and try to repeat the movements that the head is making at print time, i cant hear the sounds at all.
i cant see anything hitting the sliding blocks or directly hitting the corner wood.
The longer the prints the more frequent the sound becomes.
please let me know.
Cheers
Kym
    hi Kym,
    I have the same issue.. it is annoying, but havent been able to fix it. There has been discussion about this in the google groups:
    https://groups.google.com/forum/?pli=1# ... 8dzqZZo-cJ
    Basically this is what Chuck said:
    "Sometimes the belts will make a "popping" sound if they are mis-aligned, It's basically the belt riding up the side of the pulley and popping back into place.
    It will make a regular ticking noise. Berend made a handy tool for this:
    http://www.thingiverse.com/thing:8781
    Chuck"
    Hey Guys,
    please let me know.
    Cheers
    Kym
    I had the same thing and here's what I found on mine. It was the 'spiral plastic wrap' that the wires from the print head to the extruder motor are wrap in. When it goes in a long Y direction it compress the plastic and because of the way it's made will snap apart at the slits and make the popping sound. It may snap at one slit or several making several popping noises. It will do the same thing going back in the Y direction when it decompresses. The way I found this is just put your hand around the plastic while it's printing and you will feel the snapping. The way I fix it was just do nothing. The plastic eventually conformed to the curve it's in now and the noise went away.....that was my issue anyway..hope this might help....
        • 56 replies
        • 29 replies
