Still can't seem to figure out the issue. Solid layer infills are still pretty sparse. Tried to go back to 14.07 and have similar results.
I've done the following:
- checked the extruder to see if the teeth were gummed
- checked the drive gear was on tight and not loose
- no obstructions in the bowden tube
- filament diameter is good and entered correctly
- reflashed firmware
What else should I try to solve this issue?
gr5 2,331
Just printed some quadcopter parts with 14.09. No problems.
