When ever I see some recommendations for printing, it says something like this "0.22mm layers, 3 shells and 35% infill"
I assume they arn't using CURA.. But whilst I know what the Layer and Infill is.. What about "shells"?
Does CURA have the concept of "shells"? If so, can it be configured?? Or is this simply the same as the "Shell Thickness"? If so, whats the relationship between the shell thickness in mm, and the "number" of shells?
Jon
Just found an interesting page talking about shells, infill and layers and it seems that the "shell" is the amount of times a shell is laid.
So does this mean that if you have a 0.4mm nozzle, then a single shell is 0.4mm.. So by definition, 1.2mm shell, would be the same as 3 shells?
Jon
Daid 303
Shell thinkness in combination with the nozzle size controls the shell count.
If something says 3 shells, they most likely mean 1.5mm shell thickness, as default nozzle sizes on most machines are 0.5 and not 0.4 as on the UM.
