The only problem is my method of screwing the nuts on the tubes by hand causes the tubes to get constricted. It's not a big problem for the 4mm ID tube but I think it makes the 1/8"mm ID tube considerably harder to get the filament through. I haven't passed a 1/8" drill bit through that tube but I'll probably try it soon. I got some dies but I couldn't get the dies to carve threads in the tubes because the tubes were deforming and digging in to the dies. How do you people do it?
I also screwed the nuts directly on the tube by hand. I have no constriction issues with the 4 mm ID tube. If you haven't tried already, maybe it would help if you put something inside the 1/8" tube that fits tight while trying to thread it with a die.
helmforest 0
