Under Extrusion? I think? Help!
joseph
Posted · Under Extrusion? I think? Help!
Hello,
I have been printing some larger prints lately on my Ultimaker 2 and I am now starting to get little pin holes on the side of the prints???
I have no idea what it is from, I thought the Temp was to high so I brought it down, didnt work so I brought it up and that didnt either.
I use PLA ColorFabb Print at about 30mm/s on .1mm height with a temp of 230 normally.
I usually get perfect prints, I also tried cleaning the nozzle with a wire and didnt work.
Heres a Picture of what it looks like:
20141029 164952
Thank you,
Joseph
    Looks like under-extrusion indeed.
    You say you tried cleaning the nozzle with a wire what do you mean?
    Did you try the atomic method:
    http://support.3dverkstan.se/article/10-the
    You can also test your extrusion with the cylinder test:
    http://umforum.ultimaker.com/index.php?/topic/4586-can-your-um2-printer-achieve-10mm3s-test-it-here/
    There are multiple factors that can cause under-extrusion more info here:
    http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#underextrusion
    This is the simplest test for underextrusion. Give it a shot. Make sure to do the test at 230C so that it is valid:
    Put your spool of filament on the floor so it doesn't enter the feeder at an angle.
    I'm not 100% sure that is underextrusion but it looks like it. It wasn't *any* worse at colder temps?
        • 28 replies
