Posted · Strange behavior of GCode M140 @ UMO ??
It seems that M140 has no effect on my UMO...
The display does not show any temperature set nor any clicking of my relais using the M140 command.
I´ll try to use this commands for switching on/off a laser attachement via M140 S100 and M140 S0.
Here is a code snip for a 100x100mm square that I generated via an modified postprocessor for testing purposes:
;HEADER
G21 ;metric values
G90 ;absolute positioning
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
M106 ;heatsink assistance - fan ON
;RAPID MOVE
M104 S0 ;laser off
G0 X49.960 Y49.960 Z8.000
;Plunge Move
M140 S0 ;laser off
G1 Z1.000
;FIRST_FEED_MOVE
M140 S100 ;laser on
G1 Y150.040
;FEED_MOVE
G1 X150.040
;FEED_MOVE
G1 Y49.960
;FEED_MOVE
G1 X49.960
;Plunge Move
M140 S0 ;laser off
G1 Z0.000
;FIRST_FEED_MOVE
M140 S100 ;laser on
G1 Y150.040
;FEED_MOVE
G1 X150.040
;FEED_MOVE
G1 Y49.960
;FEED_MOVE
G1 X49.960
;Retract Move
M140 S0 ;laser off
G1 Z8.000
;FOOTER
M140 S0 ;laser off
;FOOTER
M140 S0 ;laser off
G91 ;relative positioning
G1 Z+5 X-20 Y-20 ;move Z up a bit aside
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
G0 Z80 ;move platform down
M107 ;heatsing assistance - fan OFF
M84 ;steppers off
Does anybody have an idea??
Any hints/advices???
    Japp, sure, I place a switch in my heated bed wiring to change between heated bed and laser depending on the task.
    Nevertheless, it seems that M140 has no effect...
    I think, I should see at least the temperature change at the display.
    Did a further trial today but honestly, my knowledge ends rapidly... :sad:
    Ok, today I made a new attempt - soldered a few LEDs to the UMO to see what happens...
    It seems that the M140 command switches the HB with a delay of a few seconds and that´s too slow for controlling the a laser on/off.
    Don´t know why...
    Next trial was to set a Pause between the M140´s and there at least the Ulticontroller acted as expected - again, the output was too slow to follow...
    So, seems that good advice is absolutely needed... but unfortunately something rare...
    Any hints appreciated !!
    Strange that it does that. If I were you, I would look at using one of the unused I/O pins and manipulate it via M42
    Just know that some pins are "protected". Typically, they are the ones in use.
    That might be worth trying... But afaik this is only a 5V supply and I thought connecting my laser directly at 19V...
    Pin13 should be easy to use. I'll try...
    Yes, those are 5V pins and can't sink/source a lot of current so you will need some kind of high capacity drive like a MOSFET / transistor depending on what you are driving like http://www.instructables.com/id/Connecting-a-12V-Relay-to-Arduino/
    HAHAAAAA.... it was so simple but took a loooooot of time figure it out.
    Finally I tried it with the unused Pin10 and the M42 command as anon recommended - but also nothing happened....
    After a lot of research and trial&error (mostly error) I found out that M42 commands are not buffered (ref to https://github.com/ErikZalm/Marlin/issues/666), therefore it seems that nothing happens when switching on/off - but it happens, just too fast.
    Solution: place an M400 "wait for the buffer to clear" before the M42 and Marlin will first perform all the remaining steps in the buffer and then move forward to perform the M42...
    Tadaa... swiching my dummy led on and off the right time for "cutting"...
    Unfortunately it does not work with M140, but with M42.
    NOTE: Workarroud without any warranty - but it seems to work...
    Thought it might be helpfull for somebody else...
