the green stuff is only used for the one vertical threaded rod in the back. All the other smooth rods are lubricated with light machine oil.
Hm, can't believe I missed that. You are right! It's probably the green stuff that caused the problem. Best is to clean the flat silver rods thoroughly(this is going to be tough) and apply a light sewing oil.
Titus 170
Look at shifted layers/leaning prints:
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide
It's a pulley that is not tight enough somewhere![;)](//content.invisioncic.com/ultimake/emoticons/5a33abe00be82_1f609copy.png)
