Use cura print model question.
hans.lin
Posted · Use cura print model question.
Ha ok.
The volume you are requesting to be outputed is simply too high for the temp your printing. Basically the nozzle doesn't have enough time to melt the plastic and create under extrusion. Do you sometimes ear a clicking noise in the back and the feeder skipping backward?
Try reducing print speed or raising nozzle temperature. You can also try with thinner layers height
I'll try to find the post showing the relation between speed and temp.
        • 56 replies
        • 29 replies
