Posted · um1 weird layering for tighter curves in mesh
Hi there,
I have been printing plenty of semi organic and mechanical models for years, its come to the time where i need to do some sculptures that were modeled in zbrush.
This print i did last night, 8hrs @ 50mm/sec 100mircons on an um1.
1 20141116 1135552 20141116 114337
If you look at the images, the half sphere the character is sitting on and parts of her dress and face, the layering is beautiful . but when it comes to the legs, arms and hair, the layering is not what i expected.
Im not entirely sure what i need to change, in order to get these layers to print as good as the rest of the model.
Also here is the profile that was used to print the model:
layer_height = 0.1
wall_thickness = 1
retraction_enable = True
solid_layer_thickness = 1
fill_density = 15
nozzle_size = 0.4
print_speed = 50
print_temperature = 210
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_bed_temperature = 70
support = Everywhere
platform_adhesion = None
support_dual_extrusion = First extruder
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 2.85
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_flow = 100
retraction_speed = 50.0
retraction_amount = 4.5
retraction_dual_amount = 16.5
retraction_min_travel = 1.5
retraction_combing = True
retraction_minimal_extrusion = 0.02
retraction_hop = 0.0
bottom_thickness = 0.2
object_sink = 0.0
overlap_dual = 0.2
travel_speed = 140
bottom_layer_speed = 20
infill_speed = 0.0
inset0_speed = 0.0
insetx_speed = 0.0
cool_min_layer_time = 8
fan_enabled = True
skirt_line_count = 2
skirt_gap = 3.0
skirt_minimal_length = 150.0
fan_full_height = 0.5
fan_speed = 100
fan_speed_max = 100
cool_min_feedrate = 10
cool_head_lift = False
solid_top = True
solid_bottom = True
fill_overlap = 10
support_type = Lines
support_angle = 40
support_fill_rate = 15
support_xy_distance = 0.7
support_z_distance = .15
spiralize = False
brim_line_count = 5
raft_margin = 5
raft_line_spacing = 1.0
raft_base_thickness = 0.3
raft_base_linewidth = 0.7
raft_interface_thickness = 0.2
raft_interface_linewidth = 0.2
fix_horrible_union_all_type_a = False
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = True
fix_horrible_extensive_stitching = False
plugin_config =
object_center_x = -1
object_center_y = -1
edit: im using cura 14.03. am downloading latest cura, to try that.
If anyone has time to help me debug this it would be greatly appreciated.
Im going to print some smaller busts of the model to see if it is profile settings i need to change....
Cheers
Kym
    personally I find a lower print speed more layers and maybe try with NO infill
    I find that the infill sometimes interferes with that nice round movement and jerks off and then over sails a bit.
    Plus check all the usual culprits like well lubricated rods, tight belts & pulleys. firmly sitting on its base etc.
    But I think sloooower is probably one of the biggest helps.
    James
          • Heart
        • 4 replies
