When u say does it report no heat ...do you mean inside rep g ? is there a log saying no heat is detected . I waited 2 mins as it said and it does not get hot or output any heat at all as far as i can touch .
the big round thing ...check ...these are the 2 white wires coming out of said block down to the pcb .
I will check this ...thanks .. ,we put the x / z on the wrong way through tiredness & a bit of frustration and playing with the jog shuttle control in rep g .
the only problem it seemed in building the head part was getting the right precision screwdriver size to screw in those 2 wires yellow ,red and black . But that was solved and they were on tight .
Will try to get back asap .
many thanks .
DAZ
Daid 301
First, does it report no heat, or does it not get hot? It should take about 30 seconds to get to warm to touch. If it doesn't get warm at all, check the connections of the heater element, not the temperature sensor. These connections go all the way from the heater element (big round thing you inserted into the square block) to the ultimaker PCB:
http://wiki.ultimaker.com/File:Heater1.png
Make sure you have connected it to the right heater output.
