You seem to be printing incredibly fast and cool?? 0.25mm layers at 100mm/s is 10mm^3/s - which is pretty much right at the limits of what an Ultimaker can do - with PLA at least. ABS probably behave a little bit differently in terms of extrusion rates/ You might just about be able to print PLA at that speed at temperature, but it won't be pretty. But ABS generally requires much higher temperatures, and 230 is the lower end of the print temp range for that - so combined with the very high extrusion rate, I'm not surprised that you're getting some under-extrusion and print failures.
I'd definitely go hotter and/or cooler to avoid pressure-related under-extrusion. See here for details of how the Ultimaker Original handles PLA at as you increase the extrusion rate:
http://www.extrudable.me/2013/04/18/exploring-extrusion-variability-and-limits/
superflyguy1973 0
