Thanks for the advice. I'm borrowing my friend's UM2 so I'll leave the firmware alone for now. I wanted to use this feature to connect chain links but I'll just insert it stealthily while it's printing the other links.
Normally you can also pause in the tune menu
Oh!!! Doy! I will give that a try.
gr5 1,967
I think this was a bug in earlier versions of UM2 firmware. You can update the firmware by connecting a USB cable from your computer to the UM2 and choosing "machine" "install default firmware...".
However I have not tested the pause at Z feature with my UM2 ever (only with UMO). So it's possible the bug was never fixed.
Also be aware that the latest firmware doesn't do PID control for the heated bed anymore (is always either on or off like a house thermostat) which for some unknown reason can cause the nozzle temp to fluctuate quite a bit (15C) and cause horizontal lines in prints for some people (but other's are fine). So if this happens then you can go back to roughly version 14.03. It's easy to get older versions of Cura (and hence Marlin) here:
http://software.ultimaker.com/old/
