Are you looking to pick up speed by avoiding the comb? Or are you worried about it affecting the print quality? I quite like the way cura performs combing with the retract while combing plugin enabled (with a relatively high 3mm or greater minimum distance for retract on the plugin).
If you're looking to pick up speed by skipping the combing moves, I dunno.
Daid 304
Can you show an example where this is happening? Because there are some conditions in the code to prevent insane amounts of combing when a quick retract would be faster.
