Also,why not print a calibration cube (eg. 1x1x1 cm), to rule out the model/stl cause... It will also be useful in terms of checking steps/mm.
I ended up doing just that right after I wrote the post. I wasn't able to do a test print until today but the print was a success!
Fixed
Something could be wrong with the firmware settings (which are not reset on a new firmware install). Specificly the X/Y steps per mm.
You could try a "reset to factory defaults" on your UM2. To see if that solves the issue.
Daid 303
