Support Material isn't generated under part of my model
circuitburn
Posted · Support Material isn't generated under part of my model
Hi all, I've got a little oboe key that I'm printing for a friend. As you can see from the image, I can't get any support material under the hollow oval area to the left and it's giving me printing problems.
Any recommendations? Should I try a different slicer?
    You could try adjusting the XY support distance parameter. This effects the support material in quite a few ways.
    Note that Cura currently has trouble with supporting thin area's like that.
    @ChrisR: it's actually not flat. The disk is tilted at an angle upwards leaving no totally horizontal plane with which to lay on the print bed.
    @Daid: I'll give that a try. Interestingly using the CuraEngine slicer in Repetier-Host yields proper support structure...it just won't start a print for some reason!
        • 26 replies
