bed level wizzard umo +
gizmo999
Posted · bed level wizzard umo +
check this : http://www.thingiverse.com/thing:89034
Bed Leveling Script for Ultimaker
by greengiant83, published
May 15, 2013
Description
This gcode will position the print head at each of the four corners (with room to get to the bed adjustment screws) pausing for a button press between each so that you can adjust the bed level.
It is pretty much the same thing as the bed leveling wizard in Cura except that you don't have to connect the printer to a computer to run it
    Here is my bedleveling gcode for my umo. It is for 3 point leveling but I added the middle and other corners as well.
    G21 ;metric values
    G90 ;absolute positioning
    M107 ;start with the fan off
    M117 Start Leveling - Homing X/Y
    G28 X0 Y0 ;move X/Y to min endstops
    G28 Z0 ;home Z
    M117 Start Extended Bed Leveling
    M117 Front Middle
    G1 Z2.0 F180 ;move the platform down
    G1 X103 Y0 F9000
    G1 Z0.0 F180 ;touch print head to bed
    M0 ;Pause
    M117 Back Left
    G1 X0 Y210 F9000
    M0 ;Pause
    M117 Back Right
    G1 X210 Y210 F9000
    M0 ;Pause
    M117 Middel
    G1 X105 Y105 F9000
    M0 ;Pause
    M117 Front Right
    G1 X210 Y0 F9000
    M0 ;Pause
    M117 Front Left
    G1 X0 Y0 F9000
    M0 ;Pause
    M117 Homing X/Y
    G28 X0 Y0 F9000
    M117 Leveling Done
    G00 Z20.0 F180 ;move the platform down
        • 24 replies
