Thank gr5
The temperature does not change much during printing.
Believes it may be something related to the steps / mm? because he changed the value after the exchange of 3mm filament to 1.75 mm
If yes, so how can I know the right value? today i use 95
gr5 2,067
It could be either bad Z screw but if you didn't change the Z screw it is much more likely a temperature issue. Watch the temperature carefully while it prints. See if the temperature varies. It should be consistent within 1C.
The pattern you show is what I would expect with 10C to 15C swings in temperature.
