Yes I did select the UltiMaker (5D) and currently the 5D firmware is installed on the machine. Additionally I am able to succesfully connect (Green bar at the top of RepG26) have also tried with repG(24).
- 2 months later...
I attempted to print for the first time tonight, and the same thing just happened to me, except on a fully functional Ultimaker. Any resolution to this? I bet it's something simple.
I don't know the cause, but as a solution I suggest using PrintRun. Which is a much simpler interface and hasn't caused any grief for me like RepG did.
The only "missing" feature is the ability to life tune the feedrate/flowrate.
- 1 month later...
Hi, do you have the download link for PrintRun? I would like to give it a try. thanks.
Here you go:
http://koti.kapsi.fi/~kliment/printrun/
Waaaay better than RepG......
Regards,
Toni
@Daid: BTW, I am almost only reading here and on GGroups, but great job on your side (SkeinPyPy, DaidMarlin....;-)))
Daid 303
Did you select a machine? Try selecting the ultimaker machine from the menu.
