Posted · Retraction problem?
Hello all,
On most of my parts, I think that my Ultimaker2 doesn't retracts well the filament. For instance, we can see such things:
retraction
You can clearly see the travel moves on the top layer of this part, this is not normal
Any idea how I could avoid this?
Thanks &
Merry christmas :wink:
    Its not a retraction issue. Its combing. Try disabling Combing in expert settings->retraction section.
    Combing is used to reduce retractions and simply travel on the infill instread. It does leave a mark.
    You can also use the retract on combing plugin but cant find the path at the moment (check the cura section in the forum)
