I'm printing a "lozenge" that I use to test. The issue is almost identical to the one here in term of symptoms: http://umforum.ultimaker.com/index.php?/topic/8651-gap-between-solid-infill/
I am using matterhackers pro white pla. .1 line height 50mm/s @ 210. This test little square is what I use when changing colors to make sure I get rid of the old stuff and for any testing like this.
Here is an image of some of the test prints:
Bottom:
pm_dude 27
Hi nux,
Can you show pictures of the issues? Did you try with different brand of filaments? What are your print settings?
