It must be an issue specific to Linux or to your installation. Did you try re-installing the package?
Yes. I've also checked directory permissions & they're OK.
Most probably Cura is looking at the wrong place for the plugins at execution.
To what directory does the open plugin location button lead?
Found the plugins, they're in /usr/share/cura/plugins. Tried copying them to ~/.cura/plugins, but they still don't work :-|
Some progress. It seems to be a problem with the Starting Temperature plugin. If I don't use that, the TweakAt works fine.
Starting temperature plugin? Something homebrewed... ?
No. It comes as standard with 14.12.1.
I dont have that in my plugins with 14.12.1
Not in my universe neither...: https://github.com/daid/Cura/tree/SteamEngine/plugins
oops! Must have picked up something somewhere...
Guess I'll just have to stick with TweakAt...
Dim3nsioneer 557
