Posted · Strange extrusion stop
Hi all,
i am new on this forum, so let me explain some basics of my setup.
I have bought an ultimaker about 3 years ago, so I guess this would be the 'original'.
I have upgrades the feeder mechanism with the printed bearing assembly.
Modified to direct drive and added the needed extra fan upgrades..
My recent problem now:
I had left th UM aside for about 6months and needed some larger (175mm x 70mm) parts to be printed..
I have printed the first one, which came out fine.
The second one I have already had 5attempts..
1st attempt:
Bottom layer printed perfect, but when the build was about 5mm tall, the part started looking fluffy and the extruded stopped..
The filament didn't feed through the feeder anymore and was grinding away..
- thought this was a blockage in the hot end, checked, cleaned and all looks fine..
2nd attempt: same problem, same trial to fix
I have then tried the small ultimaker robot which comes with Cura, which printed perfectly!
So no extrusion problems anymore!
3rd attempt: base layer starts off fine, but when about halfway through this layer the extrusion stops and again appears to be stuck in the Bowden tube..
Opened everything, checked, cleaned, no real issues found..
Attempt 4 and 5: tried different flow rates/temperatures and speeds but the problem remains..
I am not using raft or anything similar, the bottom of part is printed straight onto the bed..
Settings:
PLA
Initial clearance to print head: 0.1mm
Layer height: 0.1 to 0.15 (tried both)
Temp: 215 to 230 (tried various)
Print speed: 50 to 80 (tried different ones)
I am now completely out of reasoning what is wrong with the machine..
Anything obvious I am missing?
Many thanks!!
Regards
    Probably a grain or sand or similar in the head. The easiest way to clean it out is with "cold pull". Heat nozzle to 180C and push some filament through by turning the "big gear". Then let it cool to 90 to 95C (walk away for a few minutes and come back. Release the filament extruder pressure and pull very hard on the filament. About 5kg of force. If it takes > 5kg of force raise the nozzle temp by about 5C. If less than 1KG force repeat but with lower cooled temp.
    You should get a perfectly shaped casting of the nozzle tip including the last 2mm of the narrow .4mm drilled hole and the cone shaped tip.
    If not you did it too hot.
    After pulling the filament out, clip off the last inch (dirty areas) and repeat this several times. If you have hypodermics or acupuncture needles, pushing up from below the tip sometimes helps before you let it cool down from 180C.
    Alternatively remove the nozzle and burn everything out of it with gas flame and clean it out with hypodermics or wire from a brush or copper cable or similar. But the "cold pull" method is much easier.
    If you use ABS of course you will need a higher pull temp - around 130C (not 90C). Around 170C for nylon.
    Hi gr5,
    I have already tried that method twice, with no succes.
    I have then taken the assembly apart and cleaned everything:
    - Replaced the grab screw for the fillament on the feeder
    - Took the hot end apart and cleaned everything using small gas burner
    One thing I did notice: When the hot end assembly was cold, the fillament did not go through the threaded bar easily..
    When it was warm, it did go through it to reach the nozzle.
    When everything was cleaned and assembled again, the first layer started off perfect again, but after reaching 50% of the first layer, the problem started again..
    Below image of the last known problem I had.
    As you can see, it starts off OK, but then stops extruding and starts extruding again later on in the part.
    I was thinking it might be that the part is overfeeding which clogs up the nozzle and starts grinding the filament.
    So some very basic questions..
    - What is the best setting for the pressure on the fillament I am using (http://www.thingiverse.com/thing:26094, by Bertho), would you try to tighten up the spring as much as possible first, or loosen it?
    It has been mid way up to now..
    - Would you suggest a different approach to find out why the filament stops feeding in the nozzle?
    - Could this have something to do with printing long strings on the base plate, which doesn't allow enough filament to go through the nozzle, so effectively the feed rate (or flow) of the feeder is larger than what comes out of the nozzle and it starts grinding the filament lightly, until the pressure is too high and the fillament stops feeding in?
    I have read something about changing amps on the stepper motor to make it skip a rotation rather than grinding.
    Can this be done with the original ultimaker as well?
    Regards,
