bug 14.12 & 14.12.1 & 15.01-RC5
rigs
Posted · bug 14.12 & 14.12.1 & 15.01-RC5
can you check if the top and bottom layers are there in the layer view in 15.01-RC5?
The yellow bottom and top solids are missing..
Already fixed for the next RC, noticed this myself as well.
This is due to the fact that I split the top/bottom from the sparse infill. And the layer view did not know how to color the new "top/bottom skin" (and thus not coloring it at all).
This new split means you can set the top/bottom speed separate from the infill speed.
    Fixed for next version. Thanks for reporting this!
    Merci :)
    Good idea :)
