looks just like when i put it in, except for a little indentation where it mated to the brass. just make sure that it is slightly larger than the amount of teflon insert removed, so that it is pressed together when putting the hot end assembly back together.
chrisr 18
Did the piece of bowden tube resist the heat ok?
