Slow Motor Movement
Posted · Slow Motor Movement
Hi All,
Doing some experiments with dual extruder. Anyone had any issues with slow (and i mean VERY slow) motor movement.
Using cura we've fitter and extra etruder, sliced etc but on print - even if you only use one extruder the printer reduces itself to a crawl. Cant figure it out.
If you use slice3r, the settings go the other way and it becomes SO fast.
Cura is latest version, Firmware is 14.12.1.
All thoughts and help very welcome!
