Cura Gcode corrupted (?)
kolvenbag
Posted · Cura Gcode corrupted (?)
I have an object designed in SketchUp 2015. I used the 'STL Import & Export' extension to generate a STL file. This one I loaded into Cura (14.12.1). In Cura the object visually looks fine. Then I generated the Gcode and started to print. Unfortunately, in the last part of printing the object, it printed with errors (awkward forms).
What does it look like?
The object is a cup holder to be used for coffee cups in a car. I have included two screenshots:
  • A screenshot of the object loaded as STL in to Cura
  • A screenshot from the viewer I used to view the Gcode generated by Cura
What did I check/do after this happened?
  • I exported the SketchUp file again to STL (no different result)
  • I checked & repaired the STL file via NetFabb (no different result)
  • I downgraded Cura from v14.12.1 to v14.09 (no different result)
The object it self is 19.7cm x 16cm x 4.5cm.
Question
What is wrong?
Any advice is welcome.
Object As viewed In Cura 14.12.1
Object As Corrupted Gcode
    Thanks for your suggestion. I have checked the layer view in Cura ... And, yes I found there that the misprint was already visible (no reason to start printing!).
    I went back to my original design in Sketchup and found that in the pats were Cura showed the misprint, the object was having unlogical components. I changed that, exported to STL, reloaded in Cura and checked the layer view again: no errors!
    At the moment I am printing again. I will let you know the outcome of that.
    Well, those are "extra" triangles in your 3D model, which confuse Cura.
    The print result is there: everything worked out fine. The object in size and shape has been printed correctly!
    There's only one thing bothering me with this object. I think the printing time is rather long (9h:53m) for this size and simplicity.
    Looking at the way the nozzle is jumping during printing of one layer, something came to me. I noticed that the nozzle is jumping at moments that I didn't expect it to jump. What I mean is, the surface of one layer more or less has a logical pattern/order to be printed in such a way that the nozzle has minimal movement. Though I noticed that it is moving many times to reposition the nozzle and continue printing somewhere else. When you look at the printed object (see attached photo
    Nozzle jumping too much?
    ) you can actually also see that the top layer shows many movement lines.
    Do you recognize this? Do you have any idea how this happens?
    @Team Ultimaker
    I guess you are right. Probably there is some hidden geometry inside, that causes confusing for printing. I will check that.
