You don't have to remove the bowden tube to do the atomic method:
http://umforum.ultimaker.com/index.php?/topic/4118-blocked-nozzle/?p=33691
DidierKlein 729
Hi and welcome to the forum.
Have you been able to print anything at all?
Are you sure the filament has reached the nozzle? Maybe try to reload the filament, cut the end in order to make it enter easily in the nozzle.
If yes then you can try clean the nozzle using http://support.3dverkstan.se/article/10-the
