I'm seeing this, I think, because I'm using PLA that has a vicious curl on it. I've been running with
same motor setting since I got the machine. But it's gradually over latest usage, the
behaviour changes as I get to the end of a PLA roll, or now I have begun using a new roll but
one that seems to be more tightly wound on the spool, that I get this.
I'm trying to see if it's to do with too much friction at the toothed bolt. Maybe because can't advance through
hot end fast enough too ?
Just to know, before I do it, how will a motor setting change make that better ?
Regards,
Daid 301
Did you check the extruder motor power? Sounds like it is missing steps.
http://wiki.ultimaker.com/Electronics_b ... or_drivers
