Bad print on one side
printerfan
Posted · Bad print on one side
Did it look like that before the shroud? It really looks like you had no fan. Something is really messed up. Can you post a photo of your nozzle - I want to see if the tip/shoulder is worn down.
Also it would be nice to get a video of it in action - when it is doing the "support" for the hand.
I just threw out 4 things - please think about all 4 (test the left fan, was it better before the shroud, nozzle worn down (particularly by brassfill or carbon fiber), make video).
    Ok, so I realized I had the fan installed backwards, so air was flowing the wrong way. lol
    This is the new print after I flipped the fan.
    Bot 7, Feb 2
    Bot 6, Feb 2
    Bot 5, Feb 2
    Same print settings as above, except I increased print speed to 45 mm/s.
    Any recommendations to improve my print quality?
    190C
    30 mm/s
    Printed multiple objects
    All other features the same
    Used a cube as a sacrifice print via the "print all at once" feature to allow the bot more time to cool down between layers.
    The prints are excessively sticking to the bed, so I accidently broke off the "legs" of the bot when attempting to remove it from the print bed. I beleive the excessive adhesion is due to the bed being too close to the print nozzle, I will lower it for the next print.
    Any recommendations to improve the print?
    Bot 10, Feb 2
    Bot 9, Feb 2
    Bot 8, Feb 2
    It is necessary to check if your bed is balance and adjust it.
