USB printing? PronterfaceUI? My guess is on the temperature graph.
Yes to USB Printing.. Yes to Pronterface... So you think that this is simply that the graph has got too big after monitoring for so many hours.
That would certainly explain it.. Although this has only started happening from 15.01 onwards.. Can that behavior be explained?
I will do some tests to see whether its the fact that the Print UI is left open is causing this....
Thanks for the suggestion
Jon
Daid 300
