Hi Daid,
What settings are required for older electronics? What are the known symptoms of running marlin on the unsupported hardware? I know I have the Mega2550 Arduino and I believe I have the 1.5.4 electronics, but I have had issues with the newest firmware myself. I've not posted about it before because I just haven't had time to collect appropriate details and experiment...
Basically, I'm running a very old 'experimental' build of Marlin built by Bernhard Kubicek around October or November of last year. It works great, but I've tried a few times to update to a current version of Marlin and every time I end up going back to the old build. I currently print at an extrusion temperature of 175 with this firmware, but on the newer Marlin I cannot get any extrusion at all below about 220 degrees. And I don't get consistent flow and layers that stick together under 240 degrees. Even at 240 as soon as I try to take the object off the platform it just de-laminates and basically crumbles. I also get bowden tube plugs when trying to print with the new Marlin firmware at these high temps, but have no problem with them on the old experimental build... Is it possible that my temp is reading way off on the new one? Is there a setting somewhere for the thermocouple raw value to temperature mapping?
Thanks,
Troy.
Daid 298
Can you check if you have an Arduino Mega 2560, or an old Arduino Mega?
Also, check if you have 1.5.4 electronics or older. (It's on the green PCB, near the On/Off switch)
See the difference:
http://arduino.cc/en/Main/ArduinoBoardMega
http://arduino.cc/en/Main/ArduinoBoardMega2560
New machines are shipped with the 2560, but a few old machines have the older Arduino, causing the Cura updater to fail.
A few old machines are also shipped with 1.3 electronics, which require different settings to work.
