Cura Printed Non-Uniform Top Surface
inventabuild
Posted · Cura Printed Non-Uniform Top Surface
Here's some of my print settings:
Nozzle Size: 0.5mm
Bottom/Top Thickness: 0.84mm
Shell Thickness: 1.05mm
Filament Diameter 1.85mm
And here's a pic of the non-uniform top surface:
20150213_195329
Does Nozzle Size need to divide evenly into Bottom/Top Thickness to get a uniformly looking top surface?
