Hi Punker
It looks like your Peek has melted a bit.
If that's the case it means that it has gotten way above normal printing temperature.
So you would need to check your temperature is correct and being regulated.
You may need to grind the bottom of your peek flat again as well.
Daid 303
If you print is skewed, then the most common cause is too little tension in belts, or a pulley (on the axes or motor) which isn't secured tightly.
If the temperature sensor disconnects from the board on top of the printer head, then you have a major problem, as it will continue heating and your PEEK part will melt. (which smells really bad)
The head shouldn't be tilted, so the 3th picture I found odd...
