Thanks for the reply. i was trying to be cute with "Atomic Bomb". I use this term because it seems like the last report "nuclear option" for poor extrusion. I used a higher temp and removed the filament. I did the Atomic Bob clean a few more times but I still see uneven extrusion. I attached the following image to illustrate the resulting print Any suggestions are greatly appreciated.
gr5 1,514
Bob, not bomb. Atomic Bob.
So I'm not sure what you did. Are you simply saying 90C is not hot enough to pull it out? It's okay to try 95C or even 100C (95C should be fine - 90C is usually perfect). Here's the instructions for "atomic" method:
http://umforum.ultimaker.com/index.php?/topic/4118-blocked-nozzle/?p=33691
Or maybe you took the bowden off and now it's not working right? I'm just confused as to what the problem is that you are having. Or can you not take it out even at 180C? Sometimes you can get an upper print head clog. These usually occur when the 3rd fan isn't working.
Or maybe you are trying to do it and the feeder stepper is still on. Just turn the printer off to get the feeder stepper to be off and when you turn it back on avoid menu itmes that turn feeder on such as "change filament" (haven't used that in over a year now) or "move filament" or "home" or "print". I think those are the only ones that power up the feeder - instead stick with setting the nozzle temp menu item only.
